ChaosAgent
Apr 01, 2016Explorer
dougrainer wrote:ChaosAgent wrote:dougrainer wrote:
One question you asked was WHERE does the 12 volt come from for the AC tstat system. Most RV makers use the LP FURNACE 12 volt power to power the wall tstat. The Furnace has just 2 wires that go to the wall Tstat. A 12 volt positive FEED and the other is the 12 volt positive return to the furnace to start a Furnace Heat cycle. The OEM's use that 12 volt FEED to power the AC system controls. That means they do NOT have to run a separate 12 volt power wire. Doug
Doug,
That's what I figured.
The question is, where is it physically located? The wire that goes into the roof edge from the AC unit itself is a slightly difference gauge and insulation type from what ends up at the thermostat.
So there must be some sort of junction box somewhere where the two yellow wires join up and pick up the 12v.
That's what I'm looking for.
The wire can be either at the upper control box or more common at the wall tstat. Doug
Doug,
The wires I'm talking about are the ones that leave the AC area and go back into the wall of the rig and end up at the thermostat. The yellow wire that leaves the AC is not the same type of wire that ends of at the thermostat. Same color, yellow, but not the same type of wire.
Somewhere in between there is a junction box of some sort where these two yellow wires come together and also pick up the 12 volts.
Thanks for your help.
