Ava
Sep 03, 2015Explorer
My exhaust brake is very accessible in the engine compartment of my 94 Bounder with the 5.9 cummins. Mine has a small air compressor with a solenoid and an air line going to the valve on the exhaust pipe right after the turbocharger. I have a switch in the dash to activate or turn off.
If mine stopped I would first look at the voltage supplying the solenoid, check the air line, physically check for free movement at the valve and ensure switch is good. It is also connected to the transmission and there is a wire that connects both. Hope that is a start. Doug
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
