Rbertalotto wrote:
I forgot about the Bogart needing to know what type and capacity of battery....otherwise will not work properly and the monitor panel will give completely false readings. Thanks for reminding me.
"For Sale...Nearly New 12V Flooded battery!"
I just bought a 2016 trailer. It came with one battery. It has been removed and two 6 volt batteries have been installed. There older and have been mistreated. Im going to install the 12 volt battery as a back up. I will use a "Trik-L-start"(google it) It will isolate the banks and charge the 12 volt any time the other bank is being charged. Then the 12 volt bank will charge 3 cell phones a tablet and the bose portable speaker it will also run a small inverter for when the tv is mounted outside. If you set up the Trik-L-Start as a "Load" The Bogart system will work just fine. I have this setup in my motorhome to charge the start battery and it works great. (I have been charging the phones etc. With the start battery and it has worked well. Dont forget to set the second voltage to the 12 volt battery so you can keep an eye on its voltage.
