BFL13
Sep 02, 2015Explorer II
"Up to 30amp maximum solar current. Four 135w solar panels for 12v system or 8 at 24v can be accommodated"
A typical 130w panel has an Isc of 8.2a, which you will get in full sun. So a 135 will do 8.5a. Four of those makes 34a.
Then the usual advice is to have the controller able to handle 1.25 the total Isc of the array unless it has amps clipping at its max rating (that controller might have it--most PWMs don't), so normally four 135s would need a 42.5a controller (so you buy the next size up from that)
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
