- NjmurvinExplorer II
theoldwizard1 wrote:
magnusson wrote:
Can I use a 100 watt 12v portable solar panel to help charge the battery? If so how would I wire it? Thanks
100 watts is better than nothing. Just connect the output of the solar charge controller to the output of the battery bank,
It's barely better than nothing. OP has described 400ah of battery bank. He can safely discharge about 50% or 200ah. Depending on sun, angle, wiring used, etc. he will be lucky to get 6-7 usable amps at the controller in maximum daylight with a 100 watt panel. At that rate it would take about 30 hours of maximum sun to recharge 200ah.
Just basic parasitic loads (smoke alarm, propane detector, etc.) will use about an amp. Add some (very few if not LED) lights, water pump and other necessities, it doesn't take much to rack up 20-30ah overnight when the sun's not helping. This alone would be recoverable with a 100 watt panel. Add more loads than this (residential fridge, TV, DVD player, furnace,etc.) and you better bring a generator along. - laknoxNomad
Lwiddis wrote:
"being charged with 8 435w commercial grade solar panels. Whole coach will be electric, except for the water heater."
That is a serious solar system!
Ya think?! :B Induction stove, residential fridge, 1, maybe 2, heat pumps OFF THE BATTERY. Cool setup and I can hardly wait to see it.
Lyle - LwiddisNomad III"being charged with 8 435w commercial grade solar panels. Whole coach will be electric, except for the water heater."
That is a serious solar system! - theoldwizard1Explorer II
100 watts is better than nothing. Just connect the output of the solar charge controller to the output of the battery bank, - laknoxNomad
magnusson wrote:
I decided to go with 4 6v gold cart batteries wired in series parallel to increase my amp hours to run a residential fridge. Can I use a 100 watt 12v portable solar panel to help charge the battery? If so how would I wire it? Thanks
Check out my cousins' blog, www.beginningfromthismorning.com (they're on Facebook, too). They are rehabbing an old bus for a full-time RV. Juan has decided to use the battery pack from a Nissan Leaf, being charged with 8 435w commercial grade solar panels. Whole coach will be electric, except for the water heater. :)
Lyle - dave17352Explorer IIMagnussan I think I bought the same kit as you. It works great. If you want us it as a portable that should be no problem. What you need to understand is wiring the controller in is nothing more than sticking the wires from the solar panels into the controller and running two more out to your batteries. It doesn't have to be set up permanently to do this. The controller will give your batteries the proper voltage from the solar panels.
- pianotunaNomad IIIMagnusson This is what is balanced and best for twin twelve volt batteries.
As it often doesn't cost a dime more to do this, I think it is worth the trouble.
If you wish to understand the "why" surf here:
correctly interconnecting multiple twelve volt batteries
Others may say it doesn't matter--but unless there is a compelling reason to not optimize charging and discharging why not do it the best possible way? - azrvingExplorer
magnusson wrote:
Ok copy. So if I put the positive from the solar panel to the positive on one battery and the negative from the solar panel to the negative on the same battery it will charge all 4 batteries. Thanks
Being new to this stuff you may have missed the word CONTROLLER? You need a solar controller. We are trying to help you but you may be better off if you have someone do this for you so you so that it is safe. Even making connections at the batteries has it's risk of explosion if done wrong. Get someone that knows what they are doing and perhaps they can explain it as they work on it. - sch911Explorer
No...
The leads should be connected to the 12v series parallel posts that the TT uses. This will be the positive post on one battery and the negative post on another battery.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
