azrving
May 24, 2017Explorer
magnusson wrote:
Ok copy. So if I put the positive from the solar panel to the positive on one battery and the negative from the solar panel to the negative on the same battery it will charge all 4 batteries. Thanks
Being new to this stuff you may have missed the word CONTROLLER? You need a solar controller. We are trying to help you but you may be better off if you have someone do this for you so you so that it is safe. Even making connections at the batteries has it's risk of explosion if done wrong. Get someone that knows what they are doing and perhaps they can explain it as they work on it.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
