Almot
Sep 02, 2015Explorer III
BFL13 wrote:
So do I, but a quick wire swap makes it 24v :) Then you need to find some 12v as stated earlier.
Yes. There are (relatively) inexpensive DC-DC converters to run 12V loads off 24V bank. But this complicates things, more parts to fail. And you are right that non-solar charging and inverters also need to be 24V-compatible.
What SMK said - if they go to 500W, then they could consider 24V. Makes sense lowering the amps then. As it is now, with their current setup - this is just a geeky stuff, toying around.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
