enblethen
Dec 29, 2013Nomad
I would suggest running a temporary jumper from your DC power center to a location you believe is good. Any size wire will no. #16 or #18 is fine.
Use 12 volts DC positive and then do the same for the negative. This way you will know witch wire is bad.
I would also look behind the DC power center for a bih nasty wire nutted splice for the negatives. You problem circuit could have pulled out of splice.
No work has been done that may have reversed the polarity?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
