tenbear
Dec 29, 2013Explorer
Have you checked for voltage in the wire after it leaves the power panel? I have stuck a pin in a wire to check for voltage. As long as the wire is in a dry location it does no harm.
Don't forget you need a ground too. Either the +12v wire or the ground wire could be open.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
