wa8yxm
Dec 30, 2013Explorer III
Question is there a living room slide and when it is in does it block access to those two light.
That is how my RV is layed out, and there are three lights, Those two and the one over the step well, There is a switch just inside the door, near the "Salesman switch" as the battery disconnect is sometimes called, and a 2nd copy of it in my main house control panel.. They are 3-way switches and control said lights.. That way you can turn the OFF after you bring the slide in, or turn them on, turn them off as you exit and turn 'em back on soon as you open the door.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
