blanesdad
Dec 30, 2013Explorer
Thanks to all for the great advice. You are obviously more proficient than me. I guess what is so confusing is that the wires to the lights are blue with a red stripe and there is no such wire leaving the DC fuse panel. Therefore, since I can't continue to trace the wire without removing the microwave I don't have a clue where or which wire these two fixtures are spiced into. I haven't been able to locate it on the other side of the microwave (the refrigerator is next to the microwave). After I posted this I did find a wire that feeds the other two lights in the area and spliced into that wire (solid blue). Both fluorescent fixtures work fine feeding from that wire. I then tested the original bad wire (blue with red stripe) where I cut it and as I expected, no power. I would really like to find the problem.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
