Installing a new out let in the kitchen.The outside outlet has 3 wires going to it you can see under the kitchen counter.I found the one with the most slack but it looked if you cut it into the end wo...
If it looks like this the middle conductor is bare copper wire. The HOT (Black) and Neutral (White) carry the only insulation. Black to Brass and White to Silver if your outlet has screws. Ground to Green.
