Installing a new out let in the kitchen.The outside outlet has 3 wires going to it you can see under the kitchen counter.I found the one with the most slack but it looked if you cut it into the end wo...
I will add to look closely at the wire to make sure that it is only two wires. Then check to see where it is connected in electrical panel, 12 volt DC or 120 volts AC. Check to see where other end goes.
