Installing a new out let in the kitchen.The outside outlet has 3 wires going to it you can see under the kitchen counter.I found the one with the most slack but it looked if you cut it into the end wo...
What you described is known as Zip cord. It's probably 2 conductor but I have seen them have a ground. Used on lamps and fully-insulated tools. Someone added something that isn't factory. Follow it to the end and find out what's attached.
