Installing a new out let in the kitchen.The outside outlet has 3 wires going to it you can see under the kitchen counter.I found the one with the most slack but it looked if you cut it into the end wo...
Thanks for all the suggestions.After opening three of my access panels I found the other end.It connects to the so cord that goes to the slide.It does have ground wire in it.It is the only 12 ft. of 120v wire in the whole rv that is shaped like that on the outside,the rest looks like a normal flat romex. Thought inquiring minds minds would like to know the outcome.And I didn't even have to CALL AN ELECTRICIAN!
