pappy437ExplorerAug 24, 20162 Wire 120vInstalling a new out let in the kitchen.The outside outlet has 3 wires going to it you can see under the kitchen counter.I found the one with the most slack but it looked if you cut it into the end wo...Show More
enblethenNomadAug 25, 2016Thanks for the update!Wire in question could have a little better insulation for wet or damp location.Did you mark it?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related Contentslide out 120v harness issuesAdding power outlets in slide with no wiring120v Wires Near 12v Wires - -Problem?Fleetwood Angler wiring2005 SixPac D850 Wiring
