MEXICOWANDERER
Jun 28, 2015Explorer
That's what nice about the "micrometer" dial-in knobs I fitted to the Vishay pots. AGM batterues DEMAND to be charged at LOW bulk voltage set point until amperage decreases to ?1% of total amperr hour capacity before deflectimg to float. How ya gonna do that with a smart charger? In your dreams. If by some miracle I am alive to see the end of my Lifeline I would be 83. Treating any battery correctly leads to a phenomenal lifespan. I had 29 plate 8-D's that survived 1000 cycles before I gave up. Flooded Ramcar Philippine batteries. But that happened a quarter century ago.
You can PENDANT until you faint but any charging system that does not allow adjustable length of time spent at max voltage absorbsion limit is not acceptable. A huge flaw. In the case of AGM batteries it's that less than one percent goal. With flooded reaching 95% of full charge gravity is the goal as the lag over run chemical reaction will continue to raise SG
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
