- NaioExplorer II
landyacht318 wrote:
My MW rsp-500-15 gets a workout. Just yesterday it held 40 amps for an hour straight charging a fairly healthy starting battery that had been depleted to 9.23v. 14 hours after removal from meanwell, battery is at 13.14v. It was interesting to watch the inline watt meter during the first few minutes. It only wanted 23 amps at first, and voltage instantly rose to 14.45, but a minute or 2 later voltage had dropped to 12.93v and the battery was gobbling up 40 amps.
I'm gonna ask the dumb questions, but maybe they will help someone else who is lurking :).
Until I read the other thread, I thought all meanwells we user-adjustable, for output voltage. But I guess they also have a self adjusting option? And that is the norm, and what you are referring to here? Or are you talking about voltage of the battery, not the meanwell output voltage? - jrnymn7Explorermex, i believe that unit will act like my turnigy 1080w, and shut down, but i could be mistaken? the peak current at start up causes the foldback current protection, i believe it is, to drop voltage, and thus current, to zero.
- MEXICOWANDERERExplorerThe idea is to match current potential with charge acceptance of the battery. No this will not replace a converter. It is designed and intended to recharge batteries from a nominal 12.0 voltage start point. If it hiccups 26 times in the recharge, so be it. Wimpy generators are hard to work with because voltage peaks get slaughtered.
- landyacht318ExplorerThat particular unit says it employs hiccup mode protection on current overload.
http://www.onlinecomponents.com/datasheet/sp32012.aspx?p=11953405
I believe one requires constant current limiting on Overload for depleted battery charging.
This one does, for ~35$
http://pge.powergatellc.com/product_info.php/products_id/5258?osCsid=cq155jso42fiabsv7dj3j81ft3vn314vn0h1v8d11rciqnddat90
http://www.meanwell.com/webapp/product/search.aspx?prod=se-200
Having RV issues? Connect with others who have been in your shoes.24,231 PostsLatest Activity: Apr 08, 2025
