Hi li lovers! https://www.amazon.com/dp/B088RM4W48/ref=cm_sw_r_fm_apa_glt_fabc_GRTFJYCT6Z7D1BYHQ4PP?_encoding=UTF8&psc=1&fbclid=IwAR3Jvpe3whHpmzyxdYxVnTC0g6xY5oTx5QJRZICAd3aCdM9vUtIrm5aAlR8
So reading their reviews the BMS is a complete PoS. No low voltage cutoff, no low temp charge protection, etc. If you're going to monitor it closely or have a smart system upstream that can monitor and protect it then go for it, but as a throw it on the tongue and forget about it solution it's a complete fail, you'll most likely end up roaching the cells about as fast as a lead acid for 3x the cost.
