ajriding
Oct 01, 2019Explorer II
Well, it ran but not at the rated power. Glad you do not need max power. Above 4,000 feet there starts a noticeable loss in power as you ascend. The thinner air means less oxygen which means the engine is starved for fuel, well, not starved, but not getting a full portion.
It is also running rich since you cannot lean out the fuel mixture (reduce the gas to match the already reduced O2).
I have a 2200 running an AC that might peak out at 1400, but I have not tried it at 9000 feet yet. Fortunately it is rare that I will need AC at such high elevations. Nothing else I run will require anywhere near the max output of the gen.
