timmac
Feb 13, 2015Explorer
2oldman wrote:
2 is bare minimum. You need 4. Is this a new problem? Your panel should show your voltage @ 8 seconds when it quits.
Also, the Prosine has an error log, which clearly tells you what's wrong.
Its been a problem in past but my batts went bad so when I replaced them I went to group 31's with a high amp out put, was hoping this would have fixed the problem but it did not, but I have good long term 12 volts now with the newer larger batts.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
