SCVJeff
Feb 13, 2015Explorer
JesLookin wrote:OP, you are getting good suggestions and not listening.
4 gauge is smaller than 1 gauge
4/0 is much bigger than 1/0
Look at your input voltage. If you can't or won't do that then there's no reason for any of us to continue here. You can't just say what "seems" like the correct size because you have no real idea. This isn't a starter and doesn't act like one.
I suggest you find out what the REAL size of that cable is, how LONG it is, and go reference the manufacturers manual for recommended cable and max length for each size, you might be in for a shock. That microwave is going to draw between 150 -180 amps out of the batteries. That's a HUGE draw, and I wouldn't go less than 4/0. IMO you're a little short on batteries too, but those are two different problems.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
