timmac
Feb 14, 2015Explorer
2oldman wrote:mena661 wrote:The OP has started another thread soliciting suggestions for a new inverter. Apparently, without doing anything we said, and reading Amazon reviews, he has concluded his Pro is defective.
A simple measurement will tell you everything you need to know..and this thread is now closed until you check the voltage.
Go figure.
I see how people say I don't know my inverter does not know its history, when I bought this used RV about 2 years ago it worked fine, ran microwave and everything, but as time went buy it started to have issues, mostly in the past few months, the batts were older and not holding charge like it did 2 years ago so I just replaced the batts with 2 100 amp hr batts that give me 200 amp hrs now, more than the other batts but the inverter is still acting up when running the microwave, why did it work fine before with smaller batts and wires but never got better with higher amp batts, yes I could increase the wires and see what happens but with so many other complaints out there about this inverter I might as well replace it along with new 4/0 wires.
