We keep hearing about the weak trans also. We just did 4,000 mile trip with wives new to us trailer, 30 feet 8,000 pounds. 2001 3/4 ton auto trans 77,000 miles.
I carry the usual stuff along, (filters, extra belt etc.)
Pre-trip bought a tonneau cover from Geno's garage.  Surprised how good it worked. But somethings are taller than 19 inches (top of pick up box), so the room in the bed disappeared fast. And I brought way to much stuff.  Not only a hassle to carry around, also makes it hard to find stuff.
I went from the mode of:   I'll bring it just in case.  Somewhere that changed into,  if this part breaks, I've already have one at home so I'll bring, so I won't to have to buy another.  Weight added up quick.  All my fluids and filters were serviced already.  But did step up changing the brake fluid.  Also batteries were over 11 years old.  Got them tested and installed new ones.
During the trip
Had 2 problems: (that were not my fault)
One was a brass plug blew out of exhaust brake port at the exhaust fitting.  Makes a big racket that you would think the world is coming to an end. Burned a hole in the insulation above trans dip stick.
Second was ABS light came on when we were going up hill not down.  Turned out some ABS wires that come together right above the diff had wiggled the connection loose, sending a signal to dash light.  (Thanks for reminding me, I need to fix it right.  Zip tie probably not going to last all that long).
That trip was the first time I've heard the fan kick in many years. Around 100 degrees that day on the hills to Las Vegas from LA area.
No other problems and saw many same vintage, and one over 400,000 miles. Never had the pyro over 1200.  Just fell in with the trucks when it got close to 1200 on the long but not so steep hills. Watched all those with mega horse power beat me to the top of the hill.
Post trip Trailer made rear end squat down about 2 1/2 inches.  No big deal I thought but I am going to install air bags.  Trailer is "wide body" some rain spray and a few rocks are hitting front of trailer, going to install something, not sure what yet.
And going to spend the money and get fixed what our old safety director called "just more driver distractions" things like the A/C that hasn't worked for more than 5 years and getting a new radio. Old one was stolen long, long time ago.  Might even upgrade to CD versus cassette tape:B
Hope this helps, enjoy your trip
