twodownzero
Mar 07, 2019Explorer
Get a voltmeter and check your battery. What voltage is the "fair" reading on the monitor? You might have a dirty connection between monitor and battery.
Gel batteries generally use a different charge voltage than flooded or AGM. You'll need to investigate. The good news is that anything other than gel will probably be an improvement.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
