DFord
May 02, 2019Explorer
I was hoping another Roadtrek owner would jump in here with an answer for you. I've searched around without any luck. You can try contacting Roadtrek for some help/replacement or at least find a dealer near you: https://www.roadtrek.com/ You can download an owners manual there but there's noting on the window latches in it.
I'd try taking the phillips screws out to try to see more. I'm thinking you can unscrew the inside piece but can't figure out how you'd hold the outside piece while doing that. There's no sense taking the old on off till you can find a replacement. Then you'll be able to see how it's held together.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
