Chris_Bryant
May 12, 2015Explorer II
It pretty much does either work or not- the only way I know if to test the box is with everything else working correctly- the motor does have to draw enough current to shut it off. I have seen this part go bad- the part between the plastic shock absorbers and the gear, where I could just twist the gear without the motor running.
That pic is from this blog post, which doesn't really deal with your situation, but it does give some tear down pictures.
