wa8yxm
Jul 01, 2019Explorer III
You think they labeled everythign right.... Wow.
You need... a 12 volt test light (Any auto supply store/dept) this is a device shaped like an ice pick clear or translucent plastc handle with a light bulg inside and a lead with a clip.
Now ground the clip (Any handy ground) you may alo need a long oil of "Extension" wire to reach a good ground point.
Touch the window on both ends of each fuse. No need to pull the fuse. just touch touch
Bright-Brght = Good
Bright-dark or Dark-bright = Blown
Dark-Dark = no test
Bright-Brght = Good
Dark-Dark = no test
