bdpreece
Nov 02, 2014Explorer II
The Xantrex was what I had the wire nut problem with. Look between the two AC lines input/output lines and you will see an inspection plate that can be removed. Pull the plate and check the connections. Make sure you are disconnected from all power first though.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
