Kylephilipps's avatar
Kylephilipps
2003keystone cabana rebuilding bunk end
On my hybrid I noticed the bunk end has water damage. I want to rebuild it to save money but need some info. First off should I use 1/4 in plywood or 1/8 in luan? Secondly how to I get the front extior panel off with damaging it?. Thirdly a material list. I'm pretty handy just want to do,this right. Thank you.
1 Reply
  • On our Roo, our front bunk got wet after about 5 seasons. I decided to replace the wood instead of the entire panel. I did not have to remove the panel. Our Roo did not use poles to support the bed, ours had cables that were attached to the trailer body.
    I removed all the hardware from the bunk end except the piano hinge. Once the hardware was removed, removing the wood was pretty straight forward. I removed all the staples and then used a putty knife to separate the wood from the foam insulation. The wood was wet when I removed it, which probably made it easier to remove. I went with 1/4" oak plywood. I used a spray adhesive designed for foam to adhere the plywood to the foam and then put all the hardware back on.
    I let the bunk end completely dry for a few days before attaching the plywood and putting it back together. I took me, by myself, about 4 hours to tear down, replace wood and put back together. I also used Liquid Nails to adhere the plywood to the aluminum frame.
    -Michael
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
