j-d
May 27, 2015Explorer II
Don't you also have a Latching Relay (solenoid kinda thing) near your batteries, that looks like this?
Test for voltage at the two small terminals. Disconnect one of the small terminals. If the control switch is stuck "ON" then Relay should un-latch (cut 12VDC power off) or you can cycle it Latch/Un-Latch with that wire.
I really hope the 12VDC battery cables aren't connected to that little panel pictured in the OP...
