MrWizard
Jun 19, 2013Moderator
is the bottom of the compartment open
will it drop down, a transmission jack might do the job
our 6.2kw sits on two cross supports that are bolted in
I replaced the four bolts with log pieces of "all thread" rod when i needed to replace the starter
now i can lower the genset by loosing each rod 'a little at a time"
until i have lowered it to the desired position
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
