tenbear
Dec 07, 2014Explorer
Sounds like a ground problem. Have you checked the 12v ground buss?
Find a good ground and check the voltage on the negative lead at the fridge and water heater (with it turned on). If its 12v you have a bad ground.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
