CMoore-Trav's avatar
CMoore-Trav
2005 Forest River Flagstaff odd electrical problem
My 2005 Forest River Flagstaff has been serving me well since I bought it. No major issues at all but on my last RV outing I found that my fridge (both gas and electrical) didn't work and the gas water heater didn't work but the electrical water heater did. I've checked the fuses. All good. Power to the fuse panel checked with a voltmeter and that's good. However, I don't detect power to the fridge board on the outside or to the gas heater connection on the outside. Gas furnace works and gas oven works. I removed the fuse panel to checked for possible chewed wires but all the wires are good. With the fuse being good, does anyone know what the gas heater and the fridge share that I should check? The gas furnace comes on right away so I don't think it's the battery so I'm thinking I'm either missing a hidden fuse or I've got a break in a shared power line between the two.
  • I would replace the fuse and see if that corrects the problem, sometimes they "look" good and are bad. if not as suggested above with checking the ground
  • How do you know the fuse is good, did you check power on both sides? Where is the fridge and WH grounded? What ground did you use when checking power at the fridge and WH?
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
