dougrainer
Oct 16, 2023Nomad
Last, you may have a problem removing the 120 element. It looks like the shelf behind the Water Heater is slightly higher than the back of the water Heater. IF that is the case, you will have to remove all the mount screws on the outside to lift the Water Heater up a few inches to get the 120 element out. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
