Artum_Snowbird
Jul 03, 2018Explorer
I would suggest getting one of those inexpensive electrical plug testers and see if anything shows up before I started tearing into things.
A lot of campers are put together with push in wires instead of a higher grade. They get particularly finicky when heavy loads are plugged into the plugs and there is a very tiny contact point where the connectors bite into the wiring.
The odd thing about electrical wiring is the white return wire is often the problem.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
