Old-Biscuit
Jul 03, 2018Explorer III
Maryetta wrote:
Yes the GFCI kept tripping so we replaced it but the new one does the same. We replaced it with a regular receptacle to see what would happen and it works but the other 2 still do not work.
GFCI tripping cause it was sensing an issue downstream---ground fault
Need to pull each outlet and check wiring/contacts etc.
Start with outlet closest to the GFCI outlet
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
