EricCO's avatar
EricCO
Explorer II
Jun 11, 2015
2007 Norcold 510.3 Problems
Fired up the camper for the summer a couple months ago and ran into an issue where the fridge would not turn on at all.
Replaced the control board and the fridge turned on, but would not respond to power button on eyebrow board to shut off. The other two buttons worked to control temp and mode (DC/LP/AC).
Replaced DC power board, no change.
Replaced optical control board, no change.
Replace eyebrow board (buttons that control fridge), no change.
Any suggestions?
  • To test for AC Ripple.......
    An oscilloscope is best tool but you an idea of AC Ripple using a multimeter
    Connect multimeter leads to DC contacts on fridge terminal block.
    Measure DC Voltage..........But set multimeter to AC Voltage
    12.00 volt power supply with a 1 volt AC voltage superimposed on it (a ripple), you would have 1/12 * 100 = 8.3% ripple.
    Ideally AC Ripple should be less than 0.5 VAC
    Higher AC Ripple.....capacitor(s) on converter DC output are failing
  • One other thing. The brand new eyebrow board doesn't work at all. But the old one at least works with the limited functionality previously mentioned.
    I'm also sporadically getting the A code even though I have it plugged in. If I unplug the eyebrow board from the optical board and then bring the power back on the A code might go away. If it doesn't, then I disconnect and reconnect the boards and then it works except for the power button.
    Is this starting to sound like a convertor as previously mentioned?
  • Chris Bryant wrote:
    I have the troubleshooting at http://bryantrv.com/docs2/docs/norcoldboard.pdf. Are you sure you got the correct boards?
    Been using that trouble shooting document off your website from the beginning.
    I did get exact matches on oe board part numbers so confident they are correct.
  • Old-Biscuit wrote:
    Did you plug optical ribbon back in correctly.......flat side to board/arrow showing?
    Do you hold ON/OFF button until it responds....turns On or OFF?
    Check DC Power for AC Ripple........if converter is supplying 'dirty dc' it can cause issues with fridge electronics
    Yes
    On/Off button doesn't work. Worked fine for the last 8 years.
    No other electrical problems but not sure how to test for AC ripple. RV tech I hired that recommended buying the eyebrow board didn't mention the converter being broken either.
  • Did you plug optical ribbon back in correctly.......flat side to board/arrow showing?
