dougrainer
Jun 25, 2022Nomad
Skibane wrote:
^That sounds like the perfect candidate for a sealed AGM or gell battery - i.e., doesn't require adding water occasionally or cleaning corrosion off the terminals, and can be tucked away in just about any dark corner.
Remember, you have to make SURE the Coach Converter system can charge AGM/Gel batteries correctly. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
