time2roll
Jun 19, 2017Nomad
springdalejk wrote:Stay unplugged until a meter says 120 volts.
Bought a voltmeter. The 30a outlet is 240V. This is the problem.
Can I convert this to 110 somehow?
Since it was a 50 amp connection... turn off power, remove the connector, remove the hot from the neutral and cap with a wire nut, attach the neutral to the neutral, reattach connector and cover plate. Verify 120 volts.
I assume it was a NEMA 14-50R. If it was a 10-50 with no neutral you need to call a real electrician to pull or swap wires.
http://www.myrv.us/electric/Pg/30amp_Service.htm
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
