jgbo
Jun 14, 2014Explorer
Thanks, Westend. There is a disconnect switch and when I use it I can hear the relay actuate. There are also 3 relays in the 12v area and I tested all three - I put then in a circuit I new was working and heard all three actuate. I guess they could still be damaged internally - the coil working but the contact failing. I'll see if I can get some new relays today at orielly and give it a shot.
Pretty desperate :). Will be running the generator all day today in a parking lot as we're off at a sporting event...
Thanks again for the quick reply!
