old_guy
Jan 06, 2015Explorer
that one black wire is only a break in the power line. the switch turns the connection of the power to the light. there is only two ways to wire that switch working or backwards. in other words if you put one side or leg to the switch and the other to the other leg, the light will work when you press on, if wired back wards it will come on when you press off. so just reverse the wires and it will work for you.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
