eHoefler
Mar 01, 2023Explorer II
Check the solenoid valve. You have a hydraulic system, the solenoids control which slide moves. The hydraulic system does not move all 3 at the same time, mine doesn't. It will move the smallest/lightest first and the heaviest last. Run the 2 out that do move and run them to their limit and see if the last one moves then. If it doesn't, you have a solenoid valve not opening.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
