TEXAS
Feb 22, 2016Explorer
Most likely you have some trash in the carb. Clean it out and you will be ok.The one hour a month rule. Is to try and prevent varnish build up you get with the new gas. Depending on where you live. The gas can go bad fast.Storing it for over thirty days can cause problems.
