Fuzion's avatar
Fuzion
2015 Fuzion 371 Heat issues
When I turn the heat on the fan starts and runs for about a minute and shuts down. If I plug the trailer in to AC or fire the generator it starts right up. After starting the generator I can shut it off and the heater remains running until it shuts down due to reaching the proper temp, then it will not start again. Any ideas?
  • From your description it appears your 12v onboard battery is weak. Check to see if its fully charged and the water levels are good.
    Daryll
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
