Shal36
Jan 27, 2021Explorer
A couple of thoughts in attempt to be helpful.
There is a Jayco owners forum where you might find specific experiences on the same or similar issues. Hopefully, someone will have experience or insight that can help you.
Some of the HT models are known for having the sidewalls separate from the frame. This tends to happen up in the front section. I didn’t catch if this is the main slide or the bedroom/front slide, but if this is the front slide, perhaps this is some to investigate.
Hopefully something will surface that helps you solve the problem.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
