StirCrazy
Jul 22, 2025Moderator
might have a wire that is worn through and shorting somewhere. Pain in the butt to find sometimes, but you can test that theory by just using a jumper wire to temporarily take the wire you are wondering about out of the picture. if it works fine you can either inspect the wire and fix the shorted area, or just run a new wire.
- sipncruzJul 22, 2025Explorer
Yeah thats the pain in the butt part. Thought the motor would just run from the batteries but it must tie in somewhere else as well.
- StirCrazyJul 23, 2025Moderator
no the leveling motors should all tie into a circuit board and that will be fed from the battery. for example my circuit board is on the ceiling of the pass through front storage.
