Hondo99
Aug 13, 2023Explorer
Hondo99 wrote:wa8yxm wrote:
Many RVs simply do not have enough A/C.. But when you say you checked topside. Did you remove the covers and look at the FAN side of the evaporator coils.
Most A/Cs blow air through the condenser so any "Crud" that builds up on the condenser is hidden where you can't see it.
Colemans Suck. so you can easily see that they need cleaning. and it's easier to do.
It was clean, fins good , temp sensor good.
Yes! Undersized and bad insulation!
It is 2023 already should be using spray foam insulation! It been around 10 plus years!
Won’t buy another Forest River Grey Wolf!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
