- 1. Length of RV and do you have slideouts and how many
2. 50 amp or 30 amp shore power
3. Ducted or non ducted AC plenum system
4. BTU of roof unit. It is either 13,500 0r 15,000. Brand and Model of AC unit if you do not know BTU.
5. I assume 1 AC unit and not 2. Doug - wapiticountryExplorerDo you have a thermometer? If so, what temperature does the AC put out at the vent nearest the unit. It should be 30 or more degrees colder than the outside air. If it isn’t, first step is to be sure all the fins and filters are clean. Be sure it isn’t icing up due to running continuously. If that doesn’t help, time for professional or maybe replacement.
If the unit is cooling at the vents, time to start insulating the rig and defeating solar gain. Park in the shade if possible. Keep blinds shut. Pull all curtains shut. Avoid putting heat and moisture in the rig . Things l like cooking, doing laundry and showering and opening and closing by the door multiple times all go towards defeating air conditioning.
The hard truth is most RVs are not well suited for temperature extremes. The chassis build is not sufficiently insulated, the windows are not thermally efficient, and by default even the undercarriage is exposed to the elements unlike a standard residence that is attached to the ground. Florida in the summer is just as taxing on RV climate systems as North Dakota is in the winter. It can be a losing battle. - Y-GuyModeratorHondo99 I'm going to move this post to the Tech Issues forum as I think you'll get more assistance. Sharing the brand and model of your A/C unit will probably be helpful as well as the size of your Grey Wolf.
Having RV issues? Connect with others who have been in your shoes.24,314 PostsLatest Activity: Sep 06, 2025
