BigDog1333's avatar
BigDog1333
2022 Salem destination rv has no 12v batteries
Haven't seen posts about destination RVs.
When power goes out a/c thermostats don't reset. Therefore I have to reset manually.
How do I add 12 volt auxiliary to my power supply source?
I guess I didn't explain completely. This destination rv has no batteries installed. Just a converter from 120v.
Just like all RVs, lights,.thermostats and fans run on 23v.
Are all destination RVs like this?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    This like the 2nd time I've seen "Destination RV"
    IS that like a park model. NO fresh tank. No waste tank Designed to be put on a site and left there? If so then it's designed to always be plugged in and from a "House" standpoint needs not have a battery.
    Now from a Towing standpoint... Depending on the weight it may not need aux brakes (Trailer brakes) or it might have a surge brake system that also does not need electrical power... IF it has electric brakes.. then it needs an emergency brake battery.. but only if it has electric brakes.
  • Are you sure you have an inverter and not a converter? sorry I read your post wrong. just ignore this post.
  • Please read my edited post.
    This rv has no batteries just a converter.
    Meant 12v not 23v. Typo
  • I guess the first question would be: What items on the RV are 12v powered? Thermostats in a stick built house are run off a transformer, so they're not really 12v. Lights? Fridge? Water heater? If they are not 12v, then you'll have to have an INVERTER to change the battery power to 110v. And you'll have to have a CONVERTER to charge the battery(ies).
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
